4 members (pauld, J Lucas, 60steve, JoeDude), 96 guests, and 3 robots.
Topics128,203
Posts1,057,286
Members48,467
Socket Breaker
Socket Breaker
ok, old C10 is leaking coolant.
1965 Chevrolet C10
1992 5.7L / 350 chevy truck engine / with screw through valve covers
I crawled around and probed, examined...
coolant is dripping off of the big hose from the water pump to the bottom of the radiator.
so, I am looking at the hose to see if it has burst or something, but the coolant is running down the bottom/back side of the hose, I trace it up and it seems to be wet above the hose as well. HMMN.
I am thinking, the weep hole in the water pump. I can't see and actual drip tho'. The top of the harmonic balancer looks wet tho' and cool has been slung all over the underside of the hood and engine compartment. The amount of coolant is a lot, not quite pouring, but lots of coolant and plenty of drip drip dripping action.
So, I'm guessing I will be swapping out a water pump this weekend.
Open to any idears of other things to check.
Just wanted someone to check my thinking, maybe I'm missing something else to check. grin
Thanks.
-W
I think you got it. Have fun.🛠
Sounds like you did a thorough diagnostic there. I was hazard the odds to be around 95% that you have correctly pinpointed the culprit. Maybe higher.
Riding in the Passing Lane
I vote for the water pump.
George
1972 Chevy c10 Cheyenne Super
Socket Breaker
Socket Breaker
Thanks for the replies folks.
-W
Remove the fan, belt and pulley and then start looking for the leak. With those obstructions out of the way, you should be able to get a clear view of the weep hole behind the pulley hub.
Socket Breaker
Socket Breaker
Water Pump Adventure : 11/24/2017
With details and photos, if interested.
Thanks again for the replies.
Happy stoveboltin',
-W
