Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
5 members (Bill Hanlon, kades51, 49nut, JW51, 3800GUY), 570 guests, and 1 robot.
Topics126,778
Posts1,039,288
Members48,100
Most Online2,175
Jul 21st, 2025
#1240448 10/24/2017 12:14 AM
hey everyone
just picked up my new project and I need of help finding a rear wheel cylinder and brake pads for my 51 3600
thanks
Dave
Try Rockauto.com
Justhorsenround,
Did you see one listed for a 1951 3600 on Rockauto.com?
What was the bore diameter?
1 3/8" as used on 300/3900/4100? (see image below)
' Offline
Dave ,
Your REAR brake cylinders have a 1 & 3/8" piston inside the cylinder .
I come up with the Original GM part # 5450071 for the wheel cylinder .
The ' Filling Station ' has reproduction Rear Wheel Cylinders .for your 1951 3600 ..
1954 3600
Now cruising in
The Passing Lane
wow
thanks for the all the info. I didn't think it would be so hard to find parts for this truck
in todays world.
dari, It's because of your 3600 chassis. No one, at a reasonable cost has parts for your brakes. I've been there done that. If you'd rather switch to Disc brakes.
https://www.hollisterroad.com/proddetail.php?prod=47-59SRWDISC
I'm currently switching. It's taken me several years now. I'm a better Electrician than Mechanics. But I've been able to install everything so far except for some welding on the rear end.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
You might check out Jim Carter's part ME131, '46 - '52 rear. On the other hand, I found wheel cylinders for my '53 one ton at the local FLAPS. Still pricey, but less than the specialty resto places. The tricky part is finding parts numbers that aren't GM specific.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
George
I found one that says it fits 47-52 rear 3/4 and front 1 ton with a 1 3/8 bore size
does the bore size make that much of a dif if I'm not really hauling anything? the only thing I could figure is the design of the brake assembly
Crusing in the Passing Lane
If one gets larger than stock wheel cylinders, foot pedal will have more power, master might not have enough volume, smaller wheel cylinders will give foot pedal less power, use less fluid. Different size master will give opposite results.
Ed
Dave,
I'm in the same boat with you. I need pads for the rear brakes on my '51 3600...and at this point it seems my only option is to send the shoes off to Jim Carter and have them reline them. Anybody got any other options? I don't have the cash to do a swap right now.
There are plenty of OEM brake linings of all shapes and sizes on Ebay- - - -and lots of rivets. Relining brake shoes has been done for decades without a lot of special equipment- - - - -all it takes is a drill bit, a hammer, a flat-tipped punch, and something to use for an anvil. Even removing bonded linings only takes a torch to heat the shoes and loosen the glue.
Jerry,
Thanks for your response. Actually, these shoes are not riveted, they are bonded...so, I'm kinda stuck. They are also 12x2, which I cannot find anywhere. Any other ideas would be great!
Did you read the last part of Jerry's post? Heat up the shoes to get the lining off. In a pinch, you could use an angle grinder and grind the lining off, but that would be messy.
Even if they didn't have holes for rivets, those are doable as well. Just clamp the new linings in place and drill thru the holes. I find it hard to believe that you can't find 12x2 linings. You could even buy bigger and cut them down. Expand your search limits.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.437s Queries: 16 (0.094s) Memory: 0.6584 MB (Peak: 0.7754 MB) Data Comp: Zlib Server Time: 2025-09-22 17:39:48 UTC
Valid HTML 5 and Valid CSS
