1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 3,683 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,683 | As I understand it, the modern carb “dip” products are less effective than the old versions.
Any favorite concoctions for soaking a carb for rebuild?
I used lacquer thinner last time in a metal paint can. I’ve read some folks who like methyl ethyl ketone (MEK), but it sounds fairly nasty (probably why it works).
1951 3100
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Ultrasonic cleaner and Dawn dishwater soap.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Aug 2016 Posts: 107 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 107 | Carb. King can you pm me your phone #. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Who carries an ultrasonic cleaner which is big enough for a big carb which won't break the bank? A friend of mine has a small one for small engine carbs and it is absolutely amazing how well it cleans a carb.
| | | | | Joined: Jan 2014 Posts: 3,683 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,683 | I looked on amazon. The affordable ones MIGHT hold 1/3 of the carb if you break it into throttle body, float bowl, and airhorn. Even that would be questionable.
1951 3100
| | | | | Joined: Jan 2014 Posts: 3,683 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,683 | Let’s assume I can’t afford an ultrasonic cleaner (even though I want one) and we’re talking about the wonderful world of solvents.
1951 3100
| | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | JW - it is a short question, with a VERY long answer!
It all depends on the metal of the carburetor. Example, hot caustic lye does a great job on cast iron, but if you put a piece of aluminum in the tank, it will melt. But you won't see it, as you will be lying face down on the floor.
I am going to make NO suggestions other than READ THE LABEL!!!!!
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Carb. King can you pm me your phone #. 573-392-7378 (9-4 Mon-Tues central time). Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | I use the aerosol carb cleaner from the FLAPS. After you have the carb disassembled, spray it down all the orifices and then blow it out with compressed air. Using a respirator while doing this is a good idea. When I was a kid, my Dad didn't have a compressor. It was my job to pump like hell on the tire pump while he used the air to blow the crap out.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | I got one from NAPA. It is there version. Worked Very well on my Rochester B's. Even comes with a small parts basket.
1950 Chevy 3100
| | | | | Joined: Aug 2016 Posts: 107 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 107 | Tks. Jon,I guess I got ahold of you and ordered that zenith carb. Kit from you tues., Tks. For everything. Moonshine Mike | | |
