| | | Forums66 Topics128,154 Posts1,056,840 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 47 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 47 | I have received my new repro heater / switch cable for my 66 C-10. It came with no knob. The knob on the old cable is some aftermarket goober knob. I don't see replacement thrift air knobs in any of the catalogs. Would I be OK in purchasing a repro wiper knob with the set screw fastener???
Appreciate all!!
Maddog
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Bump this back to the top. I am not real familiar with the thrift set up. Is it a pull or twist function? My mental picture of a cable and a twist knob suggests the set screw might not hold. If pull, I think worth a try. | | | | | Joined: Dec 2013 Posts: 47 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 47 | It's both. The knob pulls a cable to mechanically open a vent and it turns clockwise for low, med, hi blower.
Yes, I wonder about the set screw??? if it will hold or not.
Gee...... I wonder if a a good JB weld would hold it tight? | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Some sort of glue or JB weld worth a try. | | |
