5 members (Otto Skorzeny, 2-Ton, TexasJim50, MickeyP, MRMEROTH11), 117 guests, and 3 robots.
Topics128,132
Posts1,056,383
Members48,441
are thay any good was thinking of useing it on frame after sandblast to hold it till i top coat it in spring with chassie saver ???? any help or advise is good new at the paint thing HELP
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
I would wait until spring if I was going to use etching primer and chassis paint. Sand blast, clean it good, use that metal prep stuff to get rid of any surface rust, etching primer, epoxy primer then top coat. From what I have learned from the experts here is: etching primer is porous and will let moisture get to the metal and all it to rust again. They have taught me a bunch; I hope they are proud of me too. smile ; I myself used Zero Rust on my frame and stuff. I just sandblasted, cleaned and sprayed the stuff. Done, all in one step. I am not sure that was the best way but it seems to be holding up great sitting out in the rain and stuff.
Jesus is Lord!
Only through the blood of Jesus are you washed clean of your sins.
Come see us... Dad's Chevy
Our Video
God bless you! Michael..
Some of us have tried a lot of things. I have blasted then rust-o-leum primed and rattle can painted. Also blasted and put POR15 on the chassis. I have a friend that we just blasted his chassis and he used the POR-15 kit on his chassis and it looks mighty fine. His reasoning is that while the POR=15 is a little pricey it actually cost less than buying all the rattle cans. The tip about self etching primer being porus is true. I still use it but only on stuff that is staying inside the shop or up in the attic. So when thinking what is best think what,when and where it will be.
the frame will be kept in the gerage till ready to paint
AND A MARINE
