4 members (Toadwart, Chip O, 2 invisible), 129 guests, and 2 robots.
Topics128,087
Posts1,055,998
Members48,430
#124414 02/03/2007 4:02 AM
Apprentice
Apprentice
I have a 1955 6400 (2nd series) I am taking baby steps with. Starting with the rear I was going to sandblast the frame, weld a new flatbed, etc. I told this to the mechanic I talk to and he said he would reconsider due to the sand or "media" getting in everywhere, possibly wrecking things.
Any input?
#124415 02/03/2007 4:19 AM
If you paln of overhauling everything that could be contaminated by the media, it shouldn't be a problem. You will have to count on replacing every bushing, bearing, and moving part that is exposed to the sandblas media during the process. You'll want to keep anything not being blasted away from the area when you do blast, prferrably inside a building.
Bill Burmeister
#124416 02/03/2007 4:30 AM
bad stuff for your lungs. Very bad actually.
#124417 02/03/2007 4:33 AM
Oh yeah, I should have mentioned that. Wear good safety gear.
Bill Burmeister
#124418 02/03/2007 5:29 AM
I do a lot of media blasting in my business which is firearms refinishing. We do a lot of machine guns, automatic weapons plus sniper rifles used by NATO and others. The tolerances in some of these weapons are less than you would see in a race motor. You might say everything is in the prep work. If a truck part (let's say frame) is stripped, it is a very good way to remove everything getting it ready to paint. If someone wanted to blast an engine with all the stuff still hanging on it...no way. The best way to get a truck ready to paint is explode it. If you do that then blasting (the right kind of media of course) is my way to go. It's not a black art. Find someone you trust to do your blasting and they will know what can or can't be done.
#124419 02/03/2007 3:54 PM
Sand blasting the frame would be fine. As stated above make sure any moving parts are properly covered. also freshly blasted metal will rust quickly so be ready to prime anything you have blasted at the end of the day unless you are working on the frame in a place that has low humidity. Also a quick note Sandblasting sheet metal (doors,fenders ect..) can warp it. They do make a few different types of beadblasting media that you can use on sheet metal that will not warp it.
#124420 02/03/2007 9:52 PM
^^ Properly covering moving parts can be as simple as putting a little duct tape on them.
#124421 02/04/2007 3:31 PM
Apprentice
Apprentice
I knew it would take a tremendously long time with a wire brush!!
I will have to ask around to see who does a good job.
Thanks for the help. I like the duct tape idea.
