5 members (Bill Hanlon, artinva, Hotrod Lincoln, RoadsScholar, 1 invisible), 98 guests, and 1 robot.
Topics128,078
Posts1,055,936
Members48,430
#1244153 11/21/2017 5:21 PM
As I understand it, the modern carb “dip” products are less effective than the old versions.
Any favorite concoctions for soaking a carb for rebuild?
I used lacquer thinner last time in a metal paint can. I’ve read some folks who like methyl ethyl ketone (MEK), but it sounds fairly nasty (probably why it works).
1951 3100
JW51 #1244163 11/21/2017 7:34 PM
Carburetion specialist
Ultrasonic cleaner and Dawn dishwater soap.
Jon.
The Carburetor Shop
Carb. King can you pm me your phone #.
JW51 #1244186 11/21/2017 11:02 PM
Who carries an ultrasonic cleaner which is big enough for a big carb which won't break the bank?
A friend of mine has a small one for small engine carbs and it is absolutely amazing how well it cleans a carb.
JW51 #1244196 11/22/2017 12:45 AM
I looked on amazon. The affordable ones MIGHT hold 1/3 of the carb if you break it into throttle body, float bowl, and airhorn. Even that would be questionable.
1951 3100
JW51 #1244202 11/22/2017 1:21 AM
Let’s assume I can’t afford an ultrasonic cleaner (even though I want one) and we’re talking about the wonderful world of solvents.
1951 3100
JW51 #1244205 11/22/2017 2:12 AM
JW - it is a short question, with a VERY long answer!
It all depends on the metal of the carburetor. Example, hot caustic lye does a great job on cast iron, but if you put a piece of aluminum in the tank, it will melt. But you won't see it, as you will be lying face down on the floor.
I am going to make NO suggestions other than READ THE LABEL!!!!!
Jon.
The Carburetor Shop
573-392-7378 (9-4 Mon-Tues central time).
Jon.
The Carburetor Shop
JW51 #1244222 11/22/2017 4:46 AM
Insomniac
Insomniac
I use the aerosol carb cleaner from the FLAPS. After you have the carb disassembled, spray it down all the orifices and then blow it out with compressed air. Using a respirator while doing this is a good idea.
When I was a kid, my Dad didn't have a compressor. It was my job to pump like hell on the tire pump while he used the air to blow the crap out. grin
Gord 🇨🇦
1954 1/2 ton 235 4 speed
JW51 #1244303 11/22/2017 9:28 PM
I got one from NAPA. It is there version. Worked Very well on my Rochester B's. Even comes with a small parts basket.
1950 Chevy 3100
Tks. Jon,I guess I got ahold of you and ordered that zenith carb. Kit from you tues., Tks. For everything. Moonshine Mike
