7 members (Ribside, BarryP, Ol' Red, Donf, Rusted Nut, TomGMC, 3B), 95 guests, and 2 robots.
Topics128,134
Posts1,056,738
Members48,454
#1242933 11/11/2017 4:02 PM
I was in a Tractor Supply store yesterday looking around during lunch and came across some motor oil on clearance for $4.99. It's a 2 gallon jug of "standard non-detergent motor oil, SAE 20W-20". I thought I had found a really good deal until I picked it up and started reading on the back. It said it was NOT recommended as an oil that requires additives, and was not recommended for use in automobile or truck engines. I have two questions........
1. What is this oil good for?
2. Is there any place in or on my old truck I can use this oil?
Many thanks!
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Oil the hood hinges, door hinges, tailgate pivots, and anything else that squeaks. It's also pretty good for lubricating whetstones, and keeping farm equipment from rusting. Just don't put it in an engine and expect it to work well!
Moderator
Moderator
2 Offline
Air compressors and most non combustible pistons or gear boxes that call for 20 W.
Most non auto transmissions call for a heavier W lube.
It also would work good in an oil can to use on door hinges and latches.
Home or auto.
Just a drop once in awhile and wipe excess off.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Moderator
Moderator
2 Offline
Darn it Jerry!
You type faster than me!
LOL
Don
"The Flag Pole"
1953 1-ton pickup
Ex Hall Monitor
Ex Hall Monitor
My IR compressor came with synthetic oil. Don't remember the weight.
Leo Offline
Moderator
Moderator
We used that in our portable compressor too.
Thanks for the replies fella's. I only have a small compressor so have no need for oil there, and if all this oil is good for is to lubricate hood and door hinges then 2 gallons of it, even at $4.99, doesn't sound like a bargain. I'll pass.
Chuck
1941 Chevy coupe
Well it's good for the transmission in my MGB
best oil for hinges is way oil like mobil vecrta2 it's a little sticky so it stays put
One could oil a lot of hinges with 2 gallons of oil.
Lots more pictures
That’s exactly what I said Paul!! I don’t have that many hinges!
Chuck
1941 Chevy coupe
8
8 Offline
If I recall correctly, SAE 20W-20 was the recommended oil for the Power Director in D-series Allis-Chalmers tractors.
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
I don’t have one of those in my garage. 🤪
Chuck
1941 Chevy coupe
