| | | Forums66 Topics128,032 Posts1,055,521 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 7 New Guy | | New Guy Joined: Aug 2015 Posts: 7 | Can anyone point me towards another member or other resources concerning dropping a 5.3/4l60e into 1960 apache? I'm mainly looking for swap parts, recommended fuel pump(inline or in tank), tranny cross member, vapor break for coolant system, exhaust manifold solution. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | You might do a search on "LS swap brackets/mounts" since they are rapidly becoming the engine of choice. If Chassis Engineering in Iowa has started making parts for this swap they have quality products, reasonable price, helpful to work with, and usually give you a choice of weld in or bolt in parts. We have put an LS into a 66 and made all the items in house as it was several years back and after market parts weren't available. You will need a rear sump pan but with torsion bars you should have even more room than the 66. When finished show us a picture of how and where you mount the engine and transmission control electronics since I'm not satisfied with any of ours yet. They need access to cooling air but are not very pretty.
Evan
| | | | | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | I believe Chassis Engineering in Iowa is now out of business as stated on their web site. | | | | | Joined: Sep 2008 Posts: 293 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 293 | Try the LS1Tech forum, they have a Conversions and Hybrid section which is great, these engines have been installed everywhere and there is a lot of knowledgeable guys over there!
'57 Chevy Suburban; '70 Chevy Impala.
