| Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The fenders attach to the core support, then the whole works can be bolted on. I replaced some nuts and bolts with studs next to the firewall to make it a one man operation. Don't tighten anything up 'til all is assembled.
Ed
