2 members (2-Ton, 1 invisible), 108 guests, and 2 robots.
Topics128,034
Posts1,055,546
Members48,425
#124289 01/29/2007 7:30 PM
This is more of a woodworking question but it pertains to the plywood rear floor in my 49 sub. I am trying to spray some epoxy varnish on the top side of the floor and I am getting what looks like very small fisheyes in the varnish. This didn't happen on the first coat. I had it thinned down a lot so it would sink in which it did. Now the second coat has these little bitty craters in it. I am starting to sand the second coat so it can be leveled out but before I respray it I need some help. Any suggestions out there?
Weeds
#124290 01/30/2007 2:23 AM
Weeds, Wood isn’t like metal it breaths, you need to build up slowly, very thin coats. 6 or 7 coats, it will probably take 2 or 3 coats to really seal plywood, thin about 10 to 15%
New deal for old steel
#124291 01/30/2007 2:50 AM
Weeds,
Are those things you describe as 'fish eyes' actually small bubbles. If the first coat is trying to flash off, or dry, and a second coat is applied on top of it, it will create tiny bubbles as the vapors migrate up through the fresh coat.
I think if the first coat is dry enough to sand, when you apply another coat the finish should be fine. On small items, you can run a propane torch over the finish and the bubbles will pop and level.
If these are actually fish eyes, which are usually a ...well, a thing that looks like a eye on a fish!!..maybe something has contaminated your gun. They make fish eye remover..'Smoothie', which eliminates this problem and lets the finish flow like glass. I don't know if it is compatible with your finish, but you might investigate. Good luck.
Stuart
#124292 01/30/2007 6:35 PM
Stuart and Barney, Thanks for the advice. I'm still sanding and will try more thin coats instead of heavy ones.
Weeds
#124293 01/31/2007 11:00 PM
Varnish also looks a lot better when you rub it with 4/0 steel wool inbetween coats. It tends to be gummy and have little zits on the top. A bit of elbow work makes it look much better.
Paint & Body Shop moderator
#124294 02/01/2007 4:10 PM
i echo what 4onthefloor said about the steel wool. use as fine as you can get between coats and you will be amazed at the shine you will get. it may look a little cloudy untill you spray it but then it will glow!
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
