Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Rich'sToys, EddieD, klhansen, KEVINSKI, UtahYork, 2 invisible), 52 guests, and 4 robots.
Topics128,009
Posts1,055,291
Members48,419
#124260 01/25/2007 5:07 PM
Two Questions about a visor. What should I use to paint the underside of the visor, I've seen things that recommend a flat green, not sure what to use. Also wondering if there is a source for a replacement clips that attach to the windshield molding?
Mike
My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man!
1953 Chevy 3100 Shortbed
1965 C-30 Panel Truck
1963 C-20 Long/Fleet Pick-up California Black Plate
#124261 01/25/2007 6:24 PM
the flat green was painted on the bottom side to reduce glare. not sure if there is a spec for the paint color, but if there is an area on your visor (under the panel in the center) that has not faded, you could probably color match it from that.
as far as the clips. they were missing when i first got my visor too so i just made a simple set out of some metal strap material with the intention of tracking down the real thing later. never did come across a source for them but i managed to get a set off of a donor visor. that may be your best option for finding some too.
#124262 01/25/2007 8:56 PM
We used a flat green on ours. Id does reduce the glare. NAPA used a paint analyzer to get it close to the original green. We still had the original green on the visor when we bought it.
#124263 01/26/2007 7:19 AM
The paint on the underside of My visor is
a pea green, but I am sure any dark color that is
flat will be fine too...Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
#124264 01/26/2007 7:20 AM
#124265 01/28/2007 4:05 AM
V
V Offline
yes,what they said above and there are repo brackets available on Ebay for $15.
Gangster whites and straight pipes.....
#124266 01/29/2007 1:44 AM
ebay item number 130072552502, Fulton type brackets for bid, as of Sunday Jan 28
