| | | Forums66 Topics128,005 Posts1,055,258 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 68 | Hi guys, just a question about replacing the decals on the dash board of my 42 chev truck, is it a strait forword job or can it difficult. cheers Justin | | | | | Joined: Feb 2008 Posts: 1,119 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,119 | I assume you mean the dash gauges, if so my experience was it was fairly easy. I took my time, slowed down and made sure hands and work area were clean. Tweezers, needle and sharp pointed chop stick helped as needed to maneuver some of the decals. Good luck! | | | | | Joined: Feb 2000 Posts: 5,190 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,190 | It's easy but can be tricky on the odometer numbers. Small gauges are easy, paint the needle before installing new decals if needed. Speedometer needle can be tough to get off without breaking. Clock repair shops should have the tool to pull the needle, or search eBay for clock hand removal tool. Odometer numbers have gears and pins to align, but again, not terribly hard to figure out. It's a good time to start over on mileage if your state allows it, if not record the current mileage and set new numbers to match. Be sure and install numbers going the right direction!
Joe | | | | | Joined: Feb 2008 Posts: 1,119 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,119 | I used an old dinner fork to gently pry the needle off the shaft. | | | | | Joined: Jan 2010 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 68 | thanks guys its always good get another idea on doing repairs cheers Justin | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
