0 members (),
58
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 204 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 204 | Two Questions about a visor. What should I use to paint the underside of the visor, I've seen things that recommend a flat green, not sure what to use. Also wondering if there is a source for a replacement clips that attach to the windshield molding? Thanks, Mike My old truck's still running good, my ticker's ticking like they say it should, I got supper in the oven, a good woman's loving, and even my bad days aint that bad...Yeah, I'm a lucky man! 1953 Chevy 3100 Shortbed1965 C-30 Panel Truck 1963 C-20 Long/Fleet Pick-up California Black Plate
| | | | | Joined: Jun 2005 Posts: 321 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 321 | the flat green was painted on the bottom side to reduce glare. not sure if there is a spec for the paint color, but if there is an area on your visor (under the panel in the center) that has not faded, you could probably color match it from that.
as far as the clips. they were missing when i first got my visor too so i just made a simple set out of some metal strap material with the intention of tracking down the real thing later. never did come across a source for them but i managed to get a set off of a donor visor. that may be your best option for finding some too. | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | We used a flat green on ours. Id does reduce the glare. NAPA used a paint analyzer to get it close to the original green. We still had the original green on the visor when we bought it. | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | The paint on the underside of My visor is a pea green, but I am sure any dark color that is flat will be fine too...Bill B | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | The paint on the underside of My visor is a pea green, but I am sure any dark color that is flat will be fine too...Bill B | | | | | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | yes,what they said above and there are repo brackets available on Ebay for $15.
Gangster whites and straight pipes.....
| | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | ebay item number 130072552502, Fulton type brackets for bid, as of Sunday Jan 28 | | |
