1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 46 | Hello all. I have a rebuilt inline 6 engine I'm looking to sell but I have no idea what it is worth. I know what I put into it with the block being rebuilt, the head being checked, the alternator, generator and fuel pump being rebuilt as well. Any ideas what someone would pay for this? Thanks Kevin | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | $200 - $1,000
Depending on the make/size/year of the engine. Depending on rebuild documentation you have available. Depending on how many miles & years are on the engine since the rebuild. Depending on you providing a warranty regarding oil pressure, compression, and no cracks/leaks in the block/head.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Careful Kevin, you are getting really close to breaking the offering for sale in a regular forum rule. Had you left out "I'm looking to sell" you would have been just fine. I suggest anyone wanting/offering information do so by Private Message.
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Kevin, I would make two suggestions;
1) edit your post to omit "I'm looking to sell"
2) edit your post to include specific engine etc. Stock rebuilt 216? Modified 302? Your post is too vague to get specific answers. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Depending on "who" rebuilt the engine and depending on what kind of a "rebuild" it was. To some, cleaning the grease off, spray painting it and just replacing the rings and main bearings and new gaskets is a rebuild. Proper rebuild is Magnaflux of head block and crank. New valves, hard seats and guides resurface both block side and manifold side of the head. Boil the block, re-bore block, new pistons, recondition rods, grind crank, new cam bearings check cam against specs . It has an alternator and generator, which is it??? Properly done, cost for a rebuild is between $4,000 & $5,000. Don't mean to bring you down Kevin, but the reality of it is, resale value after rebuild...... ......as Tim posted about a grand, maybe a little more if you can find the right person. After all......most guys understand that you can buy a brand new crate engine for a couple grand and have a modern dependable small block for less than half what it costs to rebuild a 60 year old Chevy 6 that's only gonna put out 1/3 the power and give you half the fuel milage. What you've sunk in to it, can only be considered a labor of love, not a good investment by most. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Aug 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 46 | Denny -- I think I'm beginning to realize that. Thanks
Martin-- I did not realize this..so thanks for pointing that out. If I continue with this I will not use forum.
Tim -- Thank you for your input as well.
Kevin S. Algonquin, IL | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good luck, Kevin S
I am usually a stickler on the "no selling outside the swap meet" rule. But, I understand your predicament - a one-time understanding. | | |
