| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 71 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 71 | Once the repair panel is welded and ground down what is recommended to use a a smoothing filler?
Ridge dweller
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Roger - the plastic fillers are the answer nowadays - check yer local store that sells body shop supplies and see what brand's prefered by the body shops in yer area - the smoother you get the repair, the finer the grade of filler you can use, and the better the result will be
Bill | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | We put a layer of fibreglass first over anything that gets welded. Thing is ya don't know if you missed a pinhole or two. The fibreglass will keep any water from getting through and causing bubbles. and what Red said^^
Good Luck. | | | | | Joined: May 2006 Posts: 35 Junior Member | | Junior Member Joined: May 2006 Posts: 35 | when you say 'layer of fiberglass' what do you mean?
a single layer of resin saturated cloth? multiple layers? just resin? on backside?
how far from the weld does it extend? thanks
bill graham
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you use fiberglas cloth and resin on steel, be aware that there is a particular type of fiberglas resin designed for applications to steel .... OTOH "bondo" type fillers, including the ones with strands [fine or coarse] are actually polyester resins, like "fiberglas", but designed for metalwork
Bill | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | A little bee's wax and 70/30 lead...Bill B | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | .......only 15,000 miles on that truck and it needed all that rust work and patch panel work done? Bill B? | | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=4;t=000682#000000
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=4;t=001819#000001
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=4;t=003553#000005 | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | delux54panel, to start with I don't mis-represent My truck to no one...I did what was necessary to get it where You see it...I did remove plastic filler as much as 2 inches thick from different area's of the body...On the left front fender over the headlight some bondo sculpturer laid a millers beer can down, then covered it with 2 inches of bondo. The truck at sometime in its life was driven through a barbed wire fence, as there was 3 deep gouges from the nose of the hood all the way to the rear of the hood...with a dolly block and a pick hammer, the gouges were lifted, and filed out...If someone had stayed away from the truck with their barrel of bondo, I would have finished much sooner...and YES 15,844 miles....Bill B??? | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | same idea as this stuff. Just mix it up, put it on, really force it in though. and then sand off just like you would any other filler. Chances are a coat of finishing putty would have to be put on top of that aswell. Good Luck. | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Bill_B That is a really nice truck. I hope mine comes out that good (but I doubt it) As far as filler I use Duraglss then regular filler over that. My tuck has so many welded in patches that it's more patches than original but it is just for me and the crew that works on the 42. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | dad, yer truck is lookin absolutely great, and I particularly like that 2-tone green! it's similar to what I have going for the project panel I hope to finish someday Bill | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | dad6timz, I looked at Your truck and it looks mighty good to Me...You and the girls will have a stovebolt to be mighty proud of, and the girls too.  Bill B | | |
