2 members (Otto Skorzeny, DHedrick), 128 guests, and 2 robots.
Topics128,088
Posts1,056,408
Members48,443
#124187 01/20/2007 2:51 PM
On my project I plan on having the non-custon look. I have two great bumpers, just surface rust on the chrome. I would like to paint them white. What is the best way to do this? (Special primer/sealer/paint?) All the bumpers I can find are chromed.
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
You don't have to do anything more than what you would normally do for the rest of the body. Sand, prep, prime and paint.
Since chrome is rather hard, initially you may have to be a little more agressive to break the glaze in order to get a good tooth for the primer. But aside from that, the rest of it is straight forward.
1949 "Heinz 57"
You can also sand blast it then follow up with some primer coats till smooth again.
I would also sandblast the chrome just because
its easier...The I would prime using something
similar to Duponts veri-prime which has a lot of
"grab" to it..The prime using regular primer, sand,
seal, and paint... Bill B.
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
The chrome on my bumper was peeling so I used a grinder to take off all the chrome. Then I prepared it in the usual way and painted it. It seems to be fine.
The crew that works on the \'42 --Sara, Hannah and Abby
I do not have a blaster, so I use the local gravestone monument maker to do my blasting. Had the front splash apron done for $5.
Kind regards from The Beautiful Blue Ridge Mountains,
Tycer
