2 members (54farmtruck, Bill Hanlon), 133 guests, and 2 robots.
Topics128,157
Posts1,056,875
Members48,456
#1241845 11/03/2017 9:21 PM
I found and purchase a 1954 Chevy 3600 w/ a 235.
From what I can tell the engine is the original motor to the truck. I want to repaint the engine to original color and from my research appears that it should be gray. However the paint traces on the motor appear to be a blue. I was planning on getting the paint from The Filling Station. Thoughts on this?
Vin# J54F017807
Engine Model# 3835911 / Serial # 0636394F54X A
DVM
Dan, welcome to the stovebolt. Its the place to be if you own an old Chevy or GMC.
Since this is the Welcome Centre its not a good place to ask technical questions, or just about any question to be honest. While we do not like "double post" I'm going to leave your post here so folks can shout out a welcome to you and I suggest you post your question in the Engine forum....or perhaps the General truck forum. Always best to ask questions in the most appropriate garage forum for the best results.
Engine color has always been a big discussion especially the "shade" of it. However, I'm sure you are wanting what is correct for your era/year of truck. Guys can answer that over in the other forum mentioned above.
Good luck and remember, we are here to help on your journey.
Hello, danM.,
Welcome to Stovebolt.com
J54F017807 = Vehicle Serial Number
J = 3600
54 = 1954
F Flint, Michigan assembly plant/factory
01787-1000 = 787th truck out of that factory in 1954
http://www.1954advance-design.com/chev-specs/1954-t-ser.jpg
3835911 1953 Corvette (after 16 October) and 1954 truck 235
0636394F54X A = Engine Serial Number
06363954-1000
F = Flint plant
54 = 1954
XA = 3600
There are casting codes on the head, post them here if you want to ID the head (it might have been changed over the years).
http://www.1954advance-design.com/Web%20images/casting-code-photos/codes-ser-nums.html
Good luck with your truck. Ask future question in one of the other fora.
Leo Offline
Moderator
Moderator
Welcome Dan, not much I can add to what Alvin already told you. Just be sure to enjoy your truck.
Leo
By the way, Dan, blue was the 1954 care-engine paint color. 1954 and later truck engines were a light gray color (but many people/members like to debate the shades of gray).
When a 235 engine got rebuilt, it was often painted the light-blue (Blue Flame Six) car engine color.
Thanks for the info!
tclederman,
What is the life span of these engines? Meaning how many miles do they generally go before needing rebuilt?
DVM
