8 members (55shaker, Bruce 1954-4100, Hanks custodian, Gdads51, BC59, Cletus1950, cmayna, 3800GUY),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,109 Posts1,056,253 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I read a post recently (can't find it now) about possible nerve damage using this product or maybe a product like this (rust encapsulator). I'm wondering if anyone out there has experienced this, what are the symptoms, does it get progressively worse, is there anything that can be done about it? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | only yer doctor can tell you what yer symptoms indicate and the prognosis! best to check a products' MDS info before use - don't know about nerve damage, but it'll sure mess up yer lungs Bill | | | | | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | A number of years ago, I sprayed a frame in an open garage with POR-15 with no mask. That night I was in the hospital with pneumonia. This stuff is nothing to play around with. It's good, but you have to protect yourself.
I called POR-15 to discuss with them after the fact and they asked me 'if I could read'. Their instructions are clear about the dangers. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Check the web page for "Rust Bullet". I have used it only with a brush so I'm unaware of the problems, if any, with spraying it. The product worked fine for me and is not a two part set-up.
| | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | Guy's...spraying any paint procucts calls for a good resp not just a paper mask,,the new products can hurt you...doc | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | brushing is Ok w/ por-15 use the very best precautions when spraying anything, airborn particulates go everywhere even inside you
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Feb 2001 Posts: 164 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 164 | The word to watch for is Isocyanates which all the moisture cured urethanes contain. You can do a web search and come up with a bunch of information. Isocyantes are one reason you don't see a lot of old painters around.... Very prevalent in the catalyzed 2 component paint systems used automotively today. It may appear they would not be in the moisture cures because they are a single package product, but you can bet your hat and the house cat, they are.
The requirements are almost uniformly for fresh air supplied breathing gear as the iso's are odorless and you cant tell when you may have lost your seal of a full face mask and are breathing it..... | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Spend a few hundred dollars on a fresh air system when spraying any kind of paint. Life is to precious. And the older you get the more you realize it. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Thanks for all the input guys; I used this stuff over a year ago, had a good mask with fresh filters, hood, goggles, face mask, coveralls, rubber gloves, etc. But I did see a post somewhere that you need a fresh air mask. Got me a little worried. | | | | | Joined: Oct 2006 Posts: 339 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 339 | Safe handling of paint materials, hardners, bondo, chemicals, the wearing of face protection is all important if You want to be in decent shape when You reach My age...when bondo dust enters Your lungs that is where it STAYS..the same for everything mentioned above...I always wear rubber gloves and long sleeve shirts because any materials that enter pores like thinners, hardners, ect...is very dangerous by causing You serious health problems. Bill B. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | this kind of product when misused will eventually allow you to be picked as a lucky candidate for CHEMOTHERAPHY! | | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | You should always have good ventaliation and where a mask when painting period. | | | | | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | My second on this. All solvent based stuff absorbs through your skin. All damage your body, some take longer than others. Always have proper ventilation!
"It ain't a truck if you can't hose out the cab."
