Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (red450IH, 50Chevy3100, Stovebolt48, Steveoreno), 169 guests, and 2 robots.
Topics128,288
Posts1,058,581
Members48,492
#124139 01/15/2007 9:34 PM
I read a post recently (can't find it now) about possible nerve damage using this product or maybe a product like this (rust encapsulator). I'm wondering if anyone out there has experienced this, what are the symptoms, does it get progressively worse, is there anything that can be done about it?
#124140 01/15/2007 11:25 PM
only yer doctor can tell you what yer symptoms indicate and the prognosis!
best to check a products' MDS info before use - don't know about nerve damage, but it'll sure mess up yer lungs
#124141 01/16/2007 12:09 AM
A number of years ago, I sprayed a frame in an open garage with POR-15 with no mask. That night I was in the hospital with pneumonia. This stuff is nothing to play around with. It's good, but you have to protect yourself.
I called POR-15 to discuss with them after the fact and they asked me 'if I could read'. Their instructions are clear about the dangers.
Jerry Acheson
Indianapolis, IN
57 Chevy 3100
#124142 01/16/2007 12:30 AM
Check the web page for "Rust Bullet". I have used it only with a brush so I'm unaware of the problems, if any, with spraying it. The product worked fine for me and is not a two part set-up.
#124143 01/16/2007 12:36 AM
Guy's...spraying any paint procucts calls for a good resp not just a paper mask,,the new products can hurt you...doc
brushing is Ok w/ por-15
use the very best precautions when spraying anything, airborn particulates go everywhere
even inside you
Jim & Caroline
The word to watch for is Isocyanates which all the moisture cured urethanes contain. You can do a web search and come up with a bunch of information.
Isocyantes are one reason you don't see a lot of old painters around.... Very prevalent in the catalyzed 2 component paint systems used automotively today. It may appear they would not be in the moisture cures because they are a single package product, but you can bet your hat and the house cat, they are.
The requirements are almost uniformly for fresh air supplied breathing gear as the iso's are odorless and you cant tell when you may have lost your seal of a full face mask and are breathing it.....
Spend a few hundred dollars on a fresh air system when spraying any kind of paint.
Life is to precious. And the older you get the more you realize it.
1949 Chevy 6400
1931 Chevy Firetruck
Thanks for all the input guys; I used this stuff over a year ago, had a good mask with fresh filters, hood, goggles, face mask, coveralls, rubber gloves, etc. But I did see a post somewhere that you need a fresh air mask. Got me a little worried.
Safe handling of paint materials, hardners,
bondo, chemicals, the wearing of face protection is
all important if You want to be in decent shape when
You reach My age...when bondo dust enters Your lungs
that is where it STAYS..the same for everything mentioned above...I always wear rubber gloves and
long sleeve shirts because any materials that enter
pores like thinners, hardners, ect...is very dangerous by causing You serious health problems.
Bill B.
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
#124149 01/16/2007 11:00 AM
1 Offline
this kind of product when misused will eventually allow you to be picked as a lucky candidate for CHEMOTHERAPHY!
You should always have good ventaliation and where a mask when painting period.
#124151 01/23/2007 10:01 PM
My second on this. All solvent based stuff absorbs through your skin. All damage your body, some take longer than others. Always have proper ventilation!
"It ain't a truck if you can't hose out the cab."
