2 members (54farmtruck, Rich'sToys), 115 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,456
Has anyone experienced the emergency brake not being able to be adjusted because the rear drums were turned to thin? One of my rear drums works, the other does not when installed on the same wheel? Confused about whether I should replace the drum.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
If the regular brake adjustment is correct the parking brake will work. Drum oversize doesn't matter.
Ah…. Thanks. you just saved me 90 bucks
Hey Hot Rod.... Your not going to believe this but I spent three hours trying to adjust the e brakes last night to no avail UNTIL I swapped the rear drum for the other one that was working and BINGO it worked! It sure seems that the drum was turned so large that the e braking wouldnt adjust out. These are old huck brakes so who knows.
Replacement cables ? Many of the Replacement cables are one size fits nothing these days.......
Huck brakes are the spawn of the devil! Having the shoes anchored at the bottom and only being able to adjust at the top makes for some oddball situations. What year vehicle are you working on?
1950 1/2 ton chevrolet Suburban
Check your private messages- - - - -
Dealing with the same thing here! I am going to try to switch the drums as well and see if that helps me. Tired of having to throw a block under the tire as fast as possible smile
Well.....it worked! New drums allowed me to adjust the e brake properly.
Curious..................Where did you purchase new drums and what was the cost ?
send a pm to yar. He's got two nos left. Super guy to deal with and very fair prices.
