8 members (FAST55, cmayna, jmoore, Gdads51, MickeyP, Biermann, papas52, Otto Skorzeny),
132
Mod | | | Forums66 Topics128,162 Posts1,056,949 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Has anyone experienced the emergency brake not being able to be adjusted because the rear drums were turned to thin? One of my rear drums works, the other does not when installed on the same wheel? Confused about whether I should replace the drum.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | If the regular brake adjustment is correct the parking brake will work. Drum oversize doesn't matter. Jerry
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Ah…. Thanks. you just saved me 90 bucks
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Hey Hot Rod.... Your not going to believe this but I spent three hours trying to adjust the e brakes last night to no avail UNTIL I swapped the rear drum for the other one that was working and BINGO it worked! It sure seems that the drum was turned so large that the e braking wouldnt adjust out. These are old huck brakes so who knows.
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Replacement cables ? Many of the Replacement cables are one size fits nothing these days....... | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Huck brakes are the spawn of the devil! Having the shoes anchored at the bottom and only being able to adjust at the top makes for some oddball situations. What year vehicle are you working on? Jerry
| | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | 1950 1/2 ton chevrolet Suburban
| | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | Check your private messages- - - - - Jerry
| | | | | Joined: Sep 2017 Posts: 19 New Guy | | New Guy Joined: Sep 2017 Posts: 19 | Dealing with the same thing here! I am going to try to switch the drums as well and see if that helps me. Tired of having to throw a block under the tire as fast as possible  | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Well.....it worked! New drums allowed me to adjust the e brake properly.
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | Curious..................Where did you purchase new drums and what was the cost ? | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | send a pm to yar. He's got two nos left. Super guy to deal with and very fair prices.
