1 members (Youngin' Tut 59),
123
Mod | | | Forums66 Topics128,201 Posts1,057,276 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | Is there a certain type of cover to buy for a vehicle / truck in a non climate controlled environment? I am planning on placing my truck in barn in the upper midwest. My truck isn't a show vehicle and has the original patina and want to minimize any additional small surface rust spots that show up from time to time. Thanks for any advice. Mice are not a problem, as of yet anyway. LOL | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Purchase one that will let the truck breathe. Since it is inside you will not need weatherproof so that will save you some money. Breathable will allow the moisture that naturally occurs on the surface of your truck to dry more quickly. Note: if you have rust starting it will continue even covered up. A good coat of wax/preservative will help.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | You need a cover that will breath so as to not trap moisture under the cover. Also as mentioned the truck has to be kept waxed to protect the paint.
My son stores his 46 2 ton truck in an old lumber supply building where years ago you would drive in one end and they would pull out the boards from the sides and load it onto the truck. Then you drive out the other end. This building is non climate controlled.
Though there are cats that get rid of the mice but they like to climb on the truck. There is also other people that store stuff there and a artist/woodworker that makes some dust once in a while.
What we do is use a fitted king size sheet on the top of the cab and the flat sheet over the hood, fenders, and grille. It keeps the truck clean and was done to prevent the cats leaving foot prints. Though for some reason the cats do not like to climb up onto the sheets.
He keeps his truck covered all year. At the end of everyday the truck is kept covered. Even at the peak of his catering season. Truck needs less washings and it keeps people from putting their hands on or them leaning against the truck in the barn.
Of course we only use 100% cotton sheets so they will breath. And better to use cotton flannel sheets because the heavier material will better protect the truck. Jeffrey
| | | | | Joined: Apr 2009 Posts: 349 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 349 | Thanks to both of you, this helps a lot. | | | | | Joined: Jul 2004 Posts: 2,994 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,994 | I would echo what Jeffrey said. See if your wife has a couple old bed sheets or blankets. If not, go to a thrift store and pick some up. Very effective and not that expensive. | | | | | Joined: Jul 2016 Posts: 22 'Bolter | | 'Bolter Joined: Jul 2016 Posts: 22 | That's a great idea, never thought of that!
Ralph
| | | | | Joined: Oct 2017 Posts: 2 Moderated | | Moderated Joined: Oct 2017 Posts: 2 | I sewed 6 'twin sheets' together to make one big cover for the whole truck (53 3100)
Scott 1953 Chevy 3100
