3 members (Steveoreno, Gdads51, GrandpasJimmy), 132 guests, and 2 robots.
Topics128,191
Posts1,057,362
Members48,469
Is there a certain type of cover to buy for a vehicle / truck in a non climate controlled environment? I am planning on placing my truck in barn in the upper midwest. My truck isn't a show vehicle and has the original patina and want to minimize any additional small surface rust spots that show up from time to time. Thanks for any advice. Mice are not a problem, as of yet anyway. LOL
1956 Chevy 3100 Stepside Shortbox
More pix on Photobucket
Purchase one that will let the truck breathe. Since it is inside you will not need weatherproof so that will save you some money. Breathable will allow the moisture that naturally occurs on the surface of your truck to dry more quickly. Note: if you have rust starting it will continue even covered up. A good coat of wax/preservative will help.
You need a cover that will breath so as to not trap moisture
under the cover. Also as mentioned the truck has to be kept
waxed to protect the paint.
My son stores his 46 2 ton truck in an old lumber supply building
where years ago you would drive in one end and they would
pull out the boards from the sides and load it onto the truck.
Then you drive out the other end. This building is non climate
controlled.
Though there are cats that get rid of the mice but they like to
climb on the truck. There is also other people that store stuff
there and a artist/woodworker that makes some dust once in
a while.
What we do is use a fitted king size sheet on the top of the cab
and the flat sheet over the hood, fenders, and grille. It keeps
the truck clean and was done to prevent the cats leaving foot
prints. Though for some reason the cats do not like to climb
up onto the sheets.
He keeps his truck covered all year. At the end of everyday the
truck is kept covered. Even at the peak of his catering season.
Truck needs less washings and it keeps people from putting
their hands on or them leaning against the truck in the barn.
Of course we only use 100% cotton sheets so they will breath.
And better to use cotton flannel sheets because the heavier
material will better protect the truck. Jeffrey
Thanks to both of you, this helps a lot.
I would echo what Jeffrey said. See if your wife has a couple old bed sheets or blankets. If not, go to a thrift store and pick some up. Very effective and not that expensive.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
That's a great idea, never thought of that!
Ralph
Moderated
Moderated
I sewed 6 'twin sheets' together to make one big cover for the whole truck (53 3100)
Scott
1953 Chevy 3100
