5 members (MickeyP, dt235sd, Wally / Montana, JW51, Bill Hanlon), 58 guests, and 2 robots.
Topics128,049
Posts1,055,699
#124132 01/15/2007 7:21 PM
How do you remove the handle from a vent glass? Is there a pin or screw in what appears to be a very small hole in the handle base?
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
djed50,
It's a dinky pin! Tap it out..there is a wave washer behind it..don't let it fly.
Stuart
thanks atomarc - now if i can just get a magnifying glass to find the hole and find something small enough to tap it out with. you do have to take it off to remove the glass don't you?
djed50,
No, you don't have to take it off to remove the vent window glass.
Stuart
that part is good news! it is pretty froze up and repeated dosings of everything i can think of has not been much help. I thought maybe if i could get it off i might be able to figure something out.
it's a roll pin, and I've seen some of those on TF trucks that only come out one direction, won't go right through, as if the hole is tapered
oh boy - something else to figure out!
