1 members (FAST55),
133
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 155 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 155 | This past Sat. we pulled the motor and the cab,, I have he cab resting on Boat dollys and I have to build a work dolly so I can move the cab around and get the metal work underway. The chassis I am thinking I can blast in its place I have a few cross members to move and a Gas tank to hang in the chassis,, let me know if anyone has any suggestions
I have a 55 second gen!,, work in progress 1963 long bed step side driver Just a guy who digs old trucks! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | A good cab dolly is a section of otherwise scrap frame from similar model truck and some scaffold wheels removable from pieces of pipe welded to each corner. The frame already has the cab mounts in the right place. wheels can be removed when transporting cab on dolly on a trailer. For working on bottom of cab remove from dolly and lay cab on something soft on the back side. | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I have seen 4 x 4s ( in a square) used that sit close to where the cab mounts on the fram. He then had wheels under it. Just a thought.
Chris | | |
