2 members (HandyAndy, mick53),
78
Mod | | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | How do you remove the handle from a vent glass? Is there a pin or screw in what appears to be a very small hole in the handle base?
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | djed50,
It's a dinky pin! Tap it out..there is a wave washer behind it..don't let it fly.
Stuart | | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | thanks atomarc - now if i can just get a magnifying glass to find the hole and find something small enough to tap it out with. you do have to take it off to remove the glass don't you?
No, you don't have to take it off to remove the vent window glass.
Stuart | | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | that part is good news! it is pretty froze up and repeated dosings of everything i can think of has not been much help. I thought maybe if i could get it off i might be able to figure something out.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's a roll pin, and I've seen some of those on TF trucks that only come out one direction, won't go right through, as if the hole is tapered
Bill | | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | oh boy - something else to figure out!
