1 members (Otto Skorzeny), 54 guests, and 3 robots.
Topics128,054
Posts1,055,779
#1240959 10/27/2017 2:04 PM
Trying to figure out the coolant capacity in my 49 suburban with a 283 and the original radiator. searched the net no luck. any help out there? need to get it winterized soon. It gets below zero here in WI. All help appreciated.
Weeds
Weeds #1240996 10/27/2017 6:13 PM
Big Bolt Forum Moderator
55 manual says 17qt. I would use that capacity. 2 gallons of antifreeze is 8 qts, which is what you want for a 50/50 mix in a 16qt system. Look on the back of the jug, and depending on how cold it gets in your area, that should be fine. You can also get an antifreeze tester to see where you are at currently.
Mike
Weeds #1241077 10/28/2017 7:22 PM
Crusing in the Passing Lane
Add a gallon of antifreeze, a gallon of distilled water, from then on, mix 50/50 in each jug and fill with that 'til full. Or if one is lazy, one can buy 50/50 premixed.
Ed
Weeds #1241784 11/03/2017 12:26 PM
A 50/50 mix freezes at -37 degrees F. If it ever gets that cold in Tennessee, I'm moving to Taihiti! Rather than paying antifreeze prices for water, I buy the concentrated stuff and mix my own 50/50 coolant, using an empty 1 gallon container and pouring it half full, then topping both off with water. Be sure to drain the block as well as the radiator to get all the water out before refilling with the coolant mix.
Weeds #1242032 11/05/2017 4:47 AM
Buying 50/50 antifreeze is like buying light beer. If I wanted light beer I would add water to my PBR!
