| | | Forums66 Topics128,109 Posts1,056,260 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Looking for a side shaft (part where shift rods come thru) for a 56 truck trans. It is a three speed.Ihave a three speed from a 55 wagon and linkage will not work. What years trans. will work? | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | I remember responding to your original post. You had removed the truck trans that should have had the correct side cover. Use the side cover from that trans on the car trans. The side cover is the same on 55 through 59 trucks except for a 55 with a 6 cylinder. Fred
| | | | | Joined: Jun 2012 Posts: 142 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 142 | Unfortunitly I got rid of the 56 trans. The person who has it can not find the side cover(trans was partially apart). | | |
