4 members (NH46COE, Hotrod Lincoln, Hanks custodian, Otto Skorzeny), 108 guests, and 7 robots.
Topics128,077
Posts1,056,031
Members48,433
#1240690 10/25/2017 11:19 PM
Looking for a side shaft (part where shift rods come thru) for a 56 truck trans. It is a three speed.Ihave a three speed from a 55 wagon and linkage will not work. What years trans. will work?
I remember responding to your original post. You had removed the truck trans that should have had the correct side cover. Use the side cover from that trans on the car trans. The side cover is the same on 55 through 59 trucks except for a 55 with a 6 cylinder.
Fred
Unfortunitly I got rid of the 56 trans. The person who has it can not find the side cover(trans was partially apart).
