3 members (Wayne67vert, crenwelge, 1 invisible),
475
Mod | | | Forums66 Topics128,282 Posts1,058,494 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12404 05/13/2005 4:18 AM | Joined: Nov 2003 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2003 Posts: 86 | Tearing down the engine to put on a stand and found the clutch fork stuck on the throw out bearing. With a little persuation,I got it off and the bearing has two ~1/16" worn spots where the fork was pressing on it. The "nubs" on the fork are now "D" shaped (not round). There seemed to be enough travel to the fork that the clutch worked just fine. Do I need to find a new fork? No one seems to list them.
Also how thick is the minimum for a clutch disc?
Thanks for your help. John
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
#12405 05/13/2005 5:32 AM | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Now that you have it torn down, you might as well replace it. Just run an ad in the parts wanted section. I'm sure someone will contact you with a good used fork. Cecil........ | | |
