3 members (Steelonsteel, Otto Skorzeny, 1 invisible), 60 guests, and 2 robots.
Topics128,054
Posts1,055,780
#1237852 10/05/2017 4:41 AM
I have a 49 3600 with a 216 in it. Will I be able to pull the oil pan off and out to replace the gasket just by removing the “screws”?
Should I replace the screws with bolts? Any advise would be helpful.
Leaks pretty bad.
Thanks Don
Can’t begin to tell you how much I hate the name Stovebolt.
Don huffer #1237882 10/05/2017 12:59 PM
1st..the pan is removable w/o pulling the engine. No need to replace the "screws", they are reusable.
Justhorsenround #1237956 10/05/2017 11:49 PM
Just thought a bolt would be better than a screw.
Don
Don huffer #1237994 10/06/2017 6:40 AM
It's just semanitcs.
Most of us think of wood screws or sheet metal screws when someone says "screw". But what we all know as bolts are also called hex head cap screws. Look them up on McMaster Carr or another site. They're just screws with machine threads instead of tapered threads like wood screws have.
Don huffer #1238008 10/06/2017 12:03 PM
If the length and threads are the same, and the bolts have what looks like a flat washer on them, it could be easier to put them back in while working from under the truck. Put the bolt in a socket with an extension and screw them in with a ratchet.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Don huffer #1238124 10/07/2017 6:22 AM
The bolts off a small block V8 oil pan will work.
1959 3100 Apache Fleetside
Don huffer #1238138 10/07/2017 1:35 PM
Don, I use bolts so that I can use my torque wrench. I tend to over-tighten if I don't. The middle bolts get tightened to a lower setting than the four corner bolts. Working from memory here, but as I recall the middle bolts get set to 6-7 foot pounds and the corner bolts get set to 12-15. I also use lock washers.
Matt
Don huffer #1238172 10/07/2017 6:44 PM
Be sure to support the vehicle om jack stands by the frame, not the axle. That will give you a couple more inches of clearance between the pan and the axle as you lower it. If you remove any rod bearing caps, be VERY careful to account for the number and placement of all the shims between the rod and the cap. That's how the oil clearance of the rods is set.
Don huffer #1240122 10/21/2017 11:20 AM
Should I use a gasket seal along with the gasket? Or just the gasket?
Don
klhansen #1240126 10/21/2017 11:52 AM
For me no matter the threads. If it has a hex head it’s a bolt. If it has a straight slot it’s an old style screw. If it has a clutch slot it gets replaced so the next guy doesn’t have the problems we did.
Thanks Don
Don huffer #1240134 10/21/2017 12:51 PM
Don, read the Stovebolt Tech Tip about Pan Gasket replacement. Tech Tips sub-section "Engines".
