| | | Forums66 Topics128,050 Posts1,055,759 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | I have a 49 3600 with a 216 in it. Will I be able to pull the oil pan off and out to replace the gasket just by removing the “screws”? Should I replace the screws with bolts? Any advise would be helpful.
Leaks pretty bad.
Thanks Don
Can’t begin to tell you how much I hate the name Stovebolt.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | 1st..the pan is removable w/o pulling the engine. No need to replace the "screws", they are reusable.
| | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | Just thought a bolt would be better than a screw.
Don
| | | | | Joined: May 2015 Posts: 11,038 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,038 | Just thought a bolt would be better than a screw. It's just semanitcs. Most of us think of wood screws or sheet metal screws when someone says "screw". But what we all know as bolts are also called hex head cap screws. Look them up on McMaster Carr or another site. They're just screws with machine threads instead of tapered threads like wood screws have.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2003 Posts: 1,061 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 1,061 | If the length and threads are the same, and the bolts have what looks like a flat washer on them, it could be easier to put them back in while working from under the truck. Put the bolt in a socket with an extension and screw them in with a ratchet.
1946 1-ton Panel 1952 1-ton Comml. W/Grain Body | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | The bolts off a small block V8 oil pan will work.
1959 3100 Apache Fleetside
| | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | Don, I use bolts so that I can use my torque wrench. I tend to over-tighten if I don't. The middle bolts get tightened to a lower setting than the four corner bolts. Working from memory here, but as I recall the middle bolts get set to 6-7 foot pounds and the corner bolts get set to 12-15. I also use lock washers.
Matt | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Be sure to support the vehicle om jack stands by the frame, not the axle. That will give you a couple more inches of clearance between the pan and the axle as you lower it. If you remove any rod bearing caps, be VERY careful to account for the number and placement of all the shims between the rod and the cap. That's how the oil clearance of the rods is set. Jerry
| | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | Should I use a gasket seal along with the gasket? Or just the gasket?
Thanks Don
| | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | For me no matter the threads. If it has a hex head it’s a bolt. If it has a straight slot it’s an old style screw. If it has a clutch slot it gets replaced so the next guy doesn’t have the problems we did.
Thanks Don
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Don, read the Stovebolt Tech Tip about Pan Gasket replacement. Tech Tips sub-section "Engines".
