6 members (3800GUY, cmayna, 52GMC35424JD, JW51, Rusty Rod, 1 invisible), 98 guests, and 5 robots.
Topics128,065
Posts1,055,863
Members48,428
#1239948 10/20/2017 12:37 AM
I have a spare 1939 216 that came with my 38 when I purchased it two years ago. I removed the valve cover the other day to have a look at the rocker arm. To my surprise I can actually move the valve springs around that aren't under some compression. I wonder how the motor ever ran like that!
1951 1 Ton Completed
I believe 1937-39 had additional springs on top of the lifters which helped with the work.
My Blog
J Online: Content
In 1939, the valve spring pressures were set at 49 - 56 pounds with valve closed, 121-133 pounds with valve open. It wouldn't take much seat wear to loosen the valve spring, and since they are weak to begin with, I am not surprised you can move them around.
Thanks for those numbers. I was going to look them up but now I don't have to! So in it's last running days those valves would have been held closed by the compression It must have made quite a racket..
truckernix #1240079 10/20/2017 10:39 PM
.010" of wear would reduce the spring tension by about 2-3 lbs.
