| | | Forums66 Topics128,078 Posts1,055,936 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | I have a ‘47 AD 3100 with a 216. Currently I have a Rochester B (manual choke) that is need of a rebuild as I can’t adjust it to idle slow to time the engine. Previously ran fine. According to Carbking the Rochester is not the most reliable/dependable. I decided to replace it with a Carter but don’t know which one. I’ve researched the GM Heritage Center and they don’t have info on the ‘47 truck. However, it appears I may have a “ Heinz 57” type engine. Consider the following data: Engine serial number– – – – – –none Engine casting number– – – – – 3835849 GM 19 Head casting number– – – – – –GM 17. 3885409. Conv 13 Head number data– – – – – – – -H 3 9 (August 3, 1949?) Intake casting number– – – – – – 3836150
So it seems I have a 1949 head on a ‘52-53 block. Since my Rochester needs rebuilding, I’d like to replace it with a Carter. But which one? One for a ‘49, ‘52,’53 or does it even matter? Originally was told this was a ‘49 engine so Carbking said a Carter 684 was correct for that year. He mentioned there was a different linkage set up so I decided to just rebuild the Rochester. Whew.......so I’m wondering if there is a certain model Carter that would best “fit” my unique 216? Any help, suggestions,advice would really help. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 52-53 216 block casting code
1949 216 head
go with the Carter 684, if that was CarbKing's recommendation. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I would try rebuilding the Roch. They are basic & easy to work on. A kit is not expensive. Also check for vacuum leaks. That can cause a fast idle. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2013 Posts: 224 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 224 | Two good suggestions. Will have to research the linkage issue. Will have to do research on the carbs for ‘52-‘53 216s a bit more also. I may rebuild both that I presently have. Decisions, decisions, decisions.... Wrenchbender Ret. That’s one area I’ve looked into already. I found D nothing. But since you suggested it I will again “re-check” my work. Perhaps I overlooked something. | | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 | I would try rebuilding the Roch. They are basic & easy to work on. A kit is not expensive. Also check for vacuum leaks. That can cause a fast idle. Especially around the throttle shaft. I'm currently rebuilding our Rochester B and found one side of the throttle shaft pretty sloppy. It was missing a few accelerator pump pieces as well so I'm excited to see how it runs after we're done.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
