3 members (fonz8261, Gdads51, 2-Ton), 83 guests, and 2 robots.
Topics128,143
Posts1,056,495
Members48,442
#1239473 10/16/2017 12:12 PM
good morning to all
i just had a motor from a 1942 carryall placed in my 1938 chevy. the motor is a 235, i had it swapped friday and its been throwing out white smoke from the exhaust. any ideas why? the local mechanics state it could be condensation in the motor? any solutions?
1937 Chevrolet Carryall http://www.oldmemoriescc.com/images/blvdbombs/images/IMG_6465_JPG.jpg
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
You might want to ID the engine.
There is an engine Serial Number pressed into the block to the rear of where the distributor enters the block. Find that code and post it here.
Here are locations of head/block codes.
White smoke is almost always water. Head gaskets, cracked head, cracked block are the usual suspects.
GM 48
3885309
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
" . . . the local mechanics state it could be condensation in the motor . . "
That is one possibility, but Martin's post above states the more likely suspects.
Were any of those mechanics the source of this motor?
Are they professional mechanics?
the mechanics are professional. one owns a auto parts store and has been giving me accurate advice over the past 20 years..
"White smoke is almost always water. Head gaskets, cracked head, cracked block are the usual suspects." i will check it out.
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
Where (from whom) did you buy the motor?
Have you ID'd the year of the motor?
Run a compression check/leak down, any ugliness will show up there.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
i will run compression test. the motor is from an early 1942 truck. its the first series of 235s with a 216 exterior look
1937 1/2 ton (sold)
1938 1/2 ton (sold)
1939 1/2 ton (sold)
Phil 4:4
