7 members (walter74, KEVINSKI, Hotrod Lincoln, Otto Skorzeny, Shade Baby, msmall, 1 invisible),
92
Mod | | | Forums66 Topics128,269 Posts1,058,401 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | I have a Canadian built 46 1/2 ton and all the panels on the interior and whatever else are flat head screws as I guess they never had the clutchhead screws when they assembled them. Does anyone know what size they are as I probably can get them from a parts or hardware store here instead of going through ordering them from the States and have to pay exorbitant postal handling charges by customs. Thanks Bob T | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Sorry Bobt, not sure. Howsabout just takin several with you when you go shopping.
There are different sizes used thruout the interior. Check the head sizes for insite on this. There are also different lengths I have found. I would consider the kit, even though they are higher priced, saves a bunch of your time figuring out what you need. | | | | | Joined: Oct 2002 Posts: 96 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 96 | Unless you order the kit and it comes and most of the screws are wrong...grrrrr | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | What a jip! Where did that kit come from? | | | | | Joined: Jul 2004 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 85 | bobt, Give American Classic a call and order their kit. I used it to replace all the flathead screws in my truck. Below is the part #
CB101 1934-46 Interior screw set, clutch head, black, Chevrolet, approximately 100 pieces $18.00 Set | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | bobt, I think you will find that most of the interior panel screws are going to be 8-32 3/8" long. However when I replaced mine I had some that were stripped, so I tapped them out to 10-32. Also the screw sets that many of the vendors have don"t have enough screws in them for the entire interior. What I did was to go and buy some round head hex drive screws of the size I needed. They come in black just like the clutch heads and unless you look real close you can't tell the difference. Hope this helps George | | | | | Joined: Jun 2005 Posts: 209 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 209 | Most clutchhead screws are hidden like inside the door panels. I replaced them so if I ever needed to adjust something or remove it it was simplier. But if your a deadon restore job go with those nightmare clutchheads. | | |
