7 members (Otto Skorzeny, Tom McGrath, Gdads51, TPR57C, 32Fordpuchoptop, Wickedbass, 1 invisible), 97 guests, and 2 robots.
Topics128,094
Posts1,056,051
Members48,433
#1238814 10/11/2017 1:37 PM
I
I Offline
Hey,
I was doin check up on my 41 which has a 47 216 in it, all this work and haven't checked spark plugs till now.
While they arnt terrible they are worn and really old, even have some rust.
What is a good replacement? The ones in there are autolite 85s. I read my manual and it said gap .040.
Stovebolter -- the Next Generation
(I'm 20)
1941 Chevy 1/2-ton pickup
"Lucy"
More pix on Photobucket
1967 Ford Mustang - "Sally"
Stock plugs used in the early days were AC-44 with .035 gap The AC44 has been discontinued but occasionally shows up on eBay.
Delco plug numbers de-code as follows: R=resistor type, 4=14 mm thread, next digit (4 or 5)=heat range (higher number is a hotter plug), S=extended tip. The R45S plugs are middle of the road heat range & should work fine if your engine is in good condition. Heat range is simply how fast heat is carried away from the plug. I believe the AC R45S (gap .040) is the correct modern plug for our “unmodified” 216 motors.
Harold
Harold
I
I Offline
Okie dokie thanks Harold
(I'm 20)
"Lucy"
Doesn't the 47 216 run a 10MM spark plug thread? I've got a 46 engine that does- - - -not sure what year they made the switch to a 14 MM thread.
I
I Offline
What plug do you suggest if it's a 10mm?
(I'm 20)
"Lucy"
I
I Offline
Got r45s and they went in good so guess it's a 14mm
(I'm 20)
"Lucy"
Ian Ring #1238880 10/11/2017 10:33 PM
Ex Hall Monitor
Ex Hall Monitor
I use AC45s in my '38 with no issues.
Jerry is correct 10mm plugs, think ACs were M 8 (I think) also used Champion UY-6
1946 1/2-Ton Chevy
Of course, it's possible the engine has had a different head installed at some time in the past. I believe there were only a few years the 10 MM plugs were used. I'm also wondering if the 10 MM head could be drilled and tapped for 14 MM plugs?
The 10mm plugs were used up through 1948.
14mm from 1949 onwards.
Post your head and block casting codes.
