1 members (Ridgeback),
42
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12385 10/03/2003 9:20 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Hi guys , I have forgotten what year GM changed the 216 from dome top pistons to flat top pistons ,, can some one please remind me ,, thanks . I want to know if a '39 head will fit onto a '47 block ?? | | |
#12386 10/03/2003 10:54 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | '37-'40 pistons are domed. The head will bolt up but you won't get much compression. | | |
#12387 10/03/2003 11:00 PM | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Forgot to add,you could mill the head to get compression. According to an old book I have,the 37-40 head can be milled as much as .187 when used with the flat top pistons and the intake valves don't have to be recessed like on a later head. | | |
#12388 10/05/2003 6:59 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Thanks brjr51 , I interperet what you have said to be that the flat top pistons started in 1941 . I think that will sort me out , thanks . | | |
