1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#12385 10/03/2003 9:20 PM
Hi guys , I have forgotten what year GM changed the 216 from dome top pistons to flat top pistons ,, can some one please remind me ,, thanks .
I want to know if a '39 head will fit onto a '47 block ??
#12386 10/03/2003 10:54 PM
'37-'40 pistons are domed. The head will bolt up but you won't get much compression.
#12387 10/03/2003 11:00 PM
Forgot to add,you could mill the head to get compression. According to an old book I have,the 37-40 head can be milled as much as .187 when used with the flat top pistons and the intake valves don't have to be recessed like on a later head.
#12388 10/05/2003 6:59 AM
Thanks brjr51 , I interperet what you have said to be that the flat top pistons started in 1941 .
I think that will sort me out , thanks .
