3 members (Peggy M, Otto Skorzeny, Ponchogl), 87 guests, and 1 robot.
Topics128,052
Posts1,055,729
#1238627 10/10/2017 4:47 AM
Hi all well I have had my first drive of truck after fitting new engine and all is good.
My question is about buying a new wiring am I better to buy a kit to suit my 42 truck with blackout lights, or am I better off doing it myself.
just a bit concerned that the kit wont have set up for blackout lights. Also I have fitted an alternator
Cheers Justin
Justin,
I bought a wiring harness from Y N Z's Wiring, in Redlands California. Mine was pretty much stock, except that they customized it for turn signals. The harness was set up perfectly. They are able to customize harnesses for alternators. Not sure about blackout lights. But, it would be worth contacting them to find out. Their tech support was great. I even got the owner on the phone once. He was very helpful as well. They don't give their harnesses away. But, they are as good a quaility as you will find. Here is a link for you.
http://www.ynzyesterdaysparts.com/
Good luck with your restoration. Hope this helps.
Rugo
Steve Rugg
53 3100
thanks Steve
I have not heard off them before, but I have just had a look at there web site.
Cheers Justin
Crusing in the Passing Lane
Aren't blackout lights on the park light circuit?
Ed
Hi all thanks for the helpful info. My switch on the truck has 3 stages, first stage pulls on the blackout lights, stage 2 pulls on the park lights, stage 3 pulls on the driving lights.
Not sure what the standard system works like?????
Another question I have is can any one tell what the rear lights look like as the lights on my truck were missing
Cheers Justin
tail lights look like this [minus the blue dots] - but you also need front and rear blackouts .... "standard" switch is 2 position, park and main .... you just need to add a circuit to the standard wire harness from the switch to power the blackout lights
Early military trucks used a round tail/brake/BO light. The bulbs are actually a self contained units. You could check military suppliers like Kaiser Willys, Midwest Military, Fitzpatcrick, etc. I purchased a complete wiring loom for an M38 from MVPC.
Fred
