6 members (Ridgeback, rick46ia, Otto Skorzeny, klhansen, MNSmith, 1 invisible), 109 guests, and 4 robots.
Topics128,022
Posts1,055,373
Members48,420
#123825 12/31/2006 10:28 PM
Junior Member
Junior Member
I need help, I have a 1961 chevy 1/2 ton short box 4x4. I bought it from the second owner, the first owner was his father in law. The truck is all origanal except paint. It is now orange in color and appears to have been painted this color more then once. I do see in spots like the firewall where paint has peeled and reveals a possible light green color. I would like to know the origanal color, but i can't find a color to match the paint code from the data plate. My paint code is RPO-710A, that is exactly how it appears on the plate. Thanks for the help
#123826 12/31/2006 11:05 PM
Welcome to the Bolt, countryboy.
Check the web page to PPG and find out their color code for that color is 11807 or check this color chart from another site to see the color.
There appears to be two turquoise colors with the designation 710A on the color sheet. Hopefully one should be closer to yours than the other.
http://www.ppgcarpaint.com/paints-bymake.php?Year=1961&AutoMakerId=52&ModelId=52
http://tcpglobal.com/autocolorlibrary/cgi-bin/search/searchpic.pl?1961-chevrolettruck-pg01.jpg
Hope this helps and hope your new year is a good one.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#123827 01/01/2007 3:03 AM
countryboy,
Here is a link to 1961 Chevrolet Truck Paint Chips & codes (I think). Be aware that these chips are 45+ years old, distorted by the scanning, and distorted by the PC's color rendering.
Hope it helps a little.
Happy New Year.
Tim
#123828 01/01/2007 4:40 AM
The chips from these sites make the color look much bluer than it is.
The chips I have are the ones offered by the site tclederman mentioned and he is absolutley correct when he mentions distortion,fading,PC's color.
The color 710A is Tampico Turquoise Metallic and is beautiful as were most colors for 61.
I saw a book recently at our local Barnes and Noble that had a listing of GM's paint codes with color chips so you can go to your local book store and have a look.Also a lot of the paint and body supply stores have old chip books and will help look up colors for you.
Hope this helps,Hobert
"The Lord is my shepherd"
#123829 01/01/2007 6:20 AM
I also have several paint books, Dupont, Ditzler(PPG), R-M, and maybe a few that no longer are around...BB
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
#123830 01/01/2007 9:57 PM
I am not looking for chips but actual touch up paint. I am touching up a 1911 Stanley Steamer with Brewster green as the main body color. I was hoping to find a small touch up bottle of paint. Has anyone seen these for the older colors? Joe
#123831 01/01/2007 10:17 PM
Here is Du ponts paint chip page. You have do a little hunting but it has some cool colors.
[url=http://www.performancecoatings.dupont.com/bowstreet5/webengine/dpc/common/Controller/Action!_pageDispatcher/InnerModel!dpc/modules/Login/OuterModel!dpc/common/Controller/InnerAction!visitorAction[url]]http://www.performancecoatings.dupont.com/bowstreet5/webengine/dpc/common/Controller/Action!_pageDispatcher/InnerModel!dpc/modules/Login/OuterModel!dpc/common/Controller/InnerActio n!visitorAction[url]
#123832 01/07/2007 5:57 AM
Junior Member
Junior Member
Joe H, Take your Stanley Steamer or a piece of it that is the color you need to a Automotive paint supplier. The most of them now days are equipted with a gun that they pass over the piece and it feeds info into a computer that tells the Saleperson what colors to mix for your need. I have been doing color matching for over 30 years and these things are Quick and very very accurate. They are great for faded out colors or ones that for some unkown reason did not come out the right color.
BAN LOW PERFORMANCE DRIVERS...
NOT HIGH PERFORMANCE CARS !!
