0 members (), 155 guests, and 4 robots.
Topics128,110
Posts1,056,241
Members48,437
#1238173 10/07/2017 6:50 PM
My engines running great! Why not add an additive smile
Seriously though, my main seal seems to be leaking a wee bit. Also my seals in my 3 speed transmission are questionable. Would an oil stabilizer / leakstop combo like Lucas oil stabilizer be an OK idea in my engine and transmission?
1955 235 engine. 3 speed manual "peanut" Transmission.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
Additives are great "feel good" purchases. They do little if anything for the performance or longevity of the engine. P.T. Barnum is alive and well, and selling automotive products.
Ahh..... I suspected
Do us all a favor and try it for one oil change cycle and get back to us with your results. I can tell you first hand the fuel additive / injector cleaner does work. My '13 Toyota goes 6 miles a day below 40 mph and after 6 months it starts running rough. So about twice a year I dose it with Lucas to restore the lost power and rough running. I have farmer friends that will not use any thing but Lucas additive and oil in there $80K tractors, they say they idle better and pull better.
I'm with Joe H on this. Try it . I fell Lucas products are better than others.
I'll try it. If my engine explodes, I will be on here looking for advice on fixing it I can assure you.
Only stop leak item I ever found that works was / is manufactured by AGS and called STOP Oil leaks. https://www.vehicleservicepros.com/...pany-stop-oil-leaks-additive-and-sealant
if it has rubber seals it usually helps. Not so much so on rope seals.
I've sold a ton of this over the years working at the parts store and everyone said it worked.
