| | | Forums66 Topics128,109 Posts1,056,269 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | My engines running great! Why not add an additive  Seriously though, my main seal seems to be leaking a wee bit. Also my seals in my 3 speed transmission are questionable. Would an oil stabilizer / leakstop combo like Lucas oil stabilizer be an OK idea in my engine and transmission? 1955 235 engine. 3 speed manual "peanut" Transmission.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Feb 2004 Posts: 29,804 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,804 | Additives are great "feel good" purchases. They do little if anything for the performance or longevity of the engine. P.T. Barnum is alive and well, and selling automotive products. Jerry
| | | | | Joined: Feb 2000 Posts: 5,219 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,219 | Do us all a favor and try it for one oil change cycle and get back to us with your results. I can tell you first hand the fuel additive / injector cleaner does work. My '13 Toyota goes 6 miles a day below 40 mph and after 6 months it starts running rough. So about twice a year I dose it with Lucas to restore the lost power and rough running. I have farmer friends that will not use any thing but Lucas additive and oil in there $80K tractors, they say they idle better and pull better. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I'm with Joe H on this. Try it . I fell Lucas products are better than others. | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | I'll try it. If my engine explodes, I will be on here looking for advice on fixing it I can assure you.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Only stop leak item I ever found that works was / is manufactured by AGS and called STOP Oil leaks. https://www.vehicleservicepros.com/...pany-stop-oil-leaks-additive-and-sealantif it has rubber seals it usually helps. Not so much so on rope seals. I've sold a ton of this over the years working at the parts store and everyone said it worked. | | |
