| | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Posted in the HiPro, but a 2 ton has some differences, like steering column. That makes this a big bolt question about the fit of a small block.
| | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | small block Ford? Your post in the hi-po section says small block and 700R4 (Chevy trans, not seen one behind a Ford).
What exactly are you wanting to do and ask? Are you trying to find out how tight it is in the engine compartment on a 2-ton? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I believe same room in small AD truck and large, engines bolt in same, same width of frame, same length between firewall and radiator. Steering box is different part number, but same physical size, also bolts in same as far as I know. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | My son just bought a 1959 2 Ton C 60. It has a 283 with a 5 speed transmission. Jeffrfey | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | A 283 would pose the same steering box problems as any small block Chev in a 50ish truck. The steering box has to be moved. Which 302 are you talking about? A small block 302 Ford or an inline GMC 302? | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | I was talking about the 302 V-8 chevy built for the Camero to compete with the Ford 302 in the Trans Am series. There was also a 307 made for several years. They were all the basically the same block with mix and match cranks and bores.
I believe the trucks after '55 had a different frame | | | | | Joined: Jan 2008 Posts: 4,963 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,963 | The 55.2 was built for a V8. The earlier ones were not and although the blocks are rather small, I think you would still hit the steering box. The engine compartment in a 2 ton is the same size as a pickup engine compartment. The 302 was a high compression, high rpm engine. 11 to one compression demanding very high octane and rated hp at 5800 RPM. It is not my idea of an engine for a 2 ton. The 307 was built for what we used to call "grocery getters". And in my opinion they are better left in the sedans they were born in. | | | | | Joined: Jul 2004 Posts: 2,995 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,995 | My '47 has a 307 in it from a '68 Impala. It was rather crudely installed by a PO but worked for what they intended it for--to haul grain. They moved the steering box over to the left a bit to get the engine in. It works for normal driving, but the tire will rub it on a hard left turn. I just try not to make any hard left turns.  | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Thanks Rich, that is the kind of info I'm looking for. | | |
