8 members (68ironhead, lumbersawyer, 48jim1ton, Woodcmiami, 3B, J Lucas, Ponchogl, 1 invisible),
97
0
Mod | | | Forums66 Topics128,049 Posts1,055,553 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | I've had my 58 Apache for 15 yrs with very few issues. It is stock and has a 235. Recently when taking her out for a drive I noticed the temp gauge started out with needle all. The way to the cold side of gauge , actually out of sight to cold side. When heated to operating temp, it registers well below the quarter way up the scale. Should I replace the sender or gauge or both? Anyway to test gauge ? Thanks for any advice. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Questions for members:
Any way to test the gauge?
Any way to test the sender?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | disconnect the wire from the sender and touch it to ground, gauge should peg hot .... or just get a new sender at your local parts store and replace it, cheap enuff
| | | | | Joined: Nov 2005 Posts: 206 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 206 | | | |
