| | | Forums66 Topics128,142 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 |  Hi all; I'm trying to find out what engine my Chevy one ton has in it. It's SUPPOSED to be a 4 bolt main 350,but who knows? The stamped # is VO214VDJ. If anyone could look it up or give ma a GOOD website where I can find it,I'd sure appreciate it. Thanks to all of you. Speed
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | What is the block casting number on the top of the bell housing flange? On cars many 4 bolt main blocks had a casting number that ended with 010 but don't know about trucks.
Evan
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Your serial number VO214VDJ breaks down as follows; V = Flint Plant 02 = Month 14 = Day VDJ = Suffix Code Check your Suffix again as that's not a good code. Could it be UDJ? If so it's a 1983 305 V8. Mike B  | | |
