2 members (Jay R, MikeStone1953), 91 guests, and 3 robots.
Topics128,026
Posts1,055,405
Members48,422
#1237349 10/01/2017 11:38 PM
I've had my 58 Apache for 15 yrs with very few issues. It is stock and has a 235. Recently when taking her out for a drive I noticed the temp gauge started out with needle all. The way to the cold side of gauge , actually out of sight to cold side. When heated to operating temp, it registers well below the quarter way up the scale. Should I replace the sender or gauge or both? Anyway to test gauge ? Thanks for any advice.
The 1958 TRI-FECTA
Stepside, Fleetside and Cameo
More Fleetside pix
More Cameo pix
More Apache Stepside pix
Questions for members:
Any way to test the gauge?
Any way to test the sender?
disconnect the wire from the sender and touch it to ground, gauge should peg hot .... or just get a new sender at your local parts store and replace it, cheap enuff
Thank you Bill
The 1958 TRI-FECTA
More Fleetside pix
More Cameo pix
