1 members (RLB),
215
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 8 Apprentice | | Apprentice Joined: Oct 2006 Posts: 8 | hey guys seems like every pic that i see people are using a saw of some kind .what is the normal cutting tool . i have a torch but don't think this is the prefered method . | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | 1965badass try using an air nibbler or an air die grinder with a cut off wheel is usually the weapon of choice DS | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | If you have a spare $1000 then go buy a plasma cutter can't beat it for a fast clean cut.
34 & 35 trucks are the greatest
| | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | Considering you may not have the spare $1000, then die grinder with cut off is the one. I have found there to be different widths of cut off disks. Use the thinest you can find as it is more accurate and cuts faster....but wear eye protection, the thin ones are more likely to grenade if twisted wrong while cutting. Torch would be a no-no. | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | I like 35 trucker's idea of Big Boy's Tools. Why use a wimpy die grinder when you can fire up the plasma arc? You could probably justify part of the cost by telling the wife that it would be great for the 4th of July and New Years Eve parties.
Actually, unless you are cutting stainless the die grinder will work just fine. Just remember eye protection because the disc do have a habit of going their own way at times. My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Dec 2002 Posts: 3,441 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,441 | sawzall's my favorite cutting tool.
