4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#1237246 10/01/2017 5:19 AM
I have a rebuilt 235 long block with a 848 head. The head was not attached to the block so I don't have any head bolts. I have been searching for a couple of hours regarding the head bolts and have read a lot of good information about them. I understand there are two lengths used but I can't find the actual number of short and long bolts. How many of each do I need? Thanks in advance
It's a small world, but I wouldn't want to paint it.
Fox Offline
Look at the head. You will be able to see where the bolts go and be able to tell if the head is thicker or thinner at that spot and this will help determine how many of each you need.
For example, along the intake/exhaust side where the bolts go is thinner, so you need the shorter bolts for that location.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
The Chevrolet Master Parts Manual that you can read on line
the at the Old Car Manual website usually gives the bolts dimensions.
Jeffrey
http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0137.htm
Thanks for the info/link.
' Offline
Herte's a couple of photos of GM NOS head bolts
I purchased back in 2010 .
I don't believe in using used head bolts .
@ photobucket
Long Bolts
http://i669.photobucket.com/albums/...%20GM%20NOS%20%203835812_zpshooekt4z.jpg
Short Bolts
http://i669.photobucket.com/albums/...t_/GM%20_NOS_Head_Bolts__zps5iayqdm5.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
Originally Posted by Rusty Shackleford
Thanks for the info/link. Are the lengths listed overall lengths? Some bolt manufacturers list the length from under the head to the end.
Rusty, read that link. It gives length, diameter, and thread. Jeffrey
I`ve got 1/2 -13 3 1/8in. (short) and 1/2-13 4 1/2in (long). Thanks for the info.
